1le
Old May 17, 2007 | 04:17 PM
71-Camaro-98's Avatar
Default 1le
What exactly is the 1LE option and how do I know if I have it?
Old May 17, 2007 | 08:15 PM
VIP1's Avatar
Copy & Paste Moderator
It was an optional suspension package that included firmer springs & shocks, larger sway bars, and stiffer rubber bushings in the LCAs and PHB (I think PHB too). If the car is equipped with it, the code "1LE' will be listed in the option code list on the divers door.
Old May 18, 2007 | 04:05 PM
where can I find out what each individual option code means?
Old May 18, 2007 | 09:59 PM
VIP1's Avatar
Here is a sticky that answers this and other questions like it:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Here is the RPO listing:
(from that sticky)
LS1
https://ls1tech.com/forums/showpost....5&postcount=17
LT1
https://ls1tech.com/forums/showpost....6&postcount=18
The sticky is located in the "New LS1 Owners - Newbie Tech" section:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech-4/
Old May 22, 2007 | 04:01 PM
greenherb's Avatar
1le is the same as a ws6 and ss for the 98 and 99...less the lca and front control arm bushings and most important koni double adjust..... by 00 gm was running out of 1le parts (i.e. 1le springs) and subed regular parts..... in other words if you have a 98 99 ws6/ ss and you do the control arms and add konis you have a repo of the 1le
