Choosing for LCAs
Thoughts?
the main downside to rod ends is that you will need to keep them lubed (or better yet, enclosed from the weather) to keep them from rusting, and they will naturally transmit a bit more noise than a bushing will. and by more noise, i'm not talking about a "clunking" noise, that's something else entirely...i just mean a bit more road noise will be transmitted since it is a stiffer piece (metal instead of rubber or poly). if you have "clunking" with rod-ends, either the rod ends are worn out, or you re-used the stock mounting hardware, which is slightly smaller diameter than the sleeve on the rod end, causing some play and making the noise.
just be sure to get new mounting hardware along with the LCA's (preferably from the manufacturer of the LCA's) so you know you have the correct diameter hardware, and keep them lubed to prevent rust. also, make sure they have good quality rod ends, like QA1 ends.
