Does your FBODY wonder?
the answer?!....SLOW DOWN hahah! as if. mine only does this at high speeds on the freeway where the big trucks drive.
is this something that having a solid rear axle creates or would a car with IRS do this too?
Caster uses the weight of the car to help keep the wheels straight. the more positive caster, the more the wheels will want to stay straight, obviously this increases steering effort since the weight will be forcing (a little bit) the wheels to stay in a straight line. it isnt really that big a deal with power steering, but if you got manual steering you dont really wanna go too positive.
Caster effects steering so much, that the side with the least positive caster will tend to pull the car in that direction. so crank up that caster guys, and maybe it'll cut back on the wandering. maybe the factory recommended specs just arent enough.
also i might add, if both wheels are toed in a little it might keep the car straight, but it'll eat the hell out of the tires due to scrubbing...
am i wrong?
Anyways, I've heard that a good example of camber is the front wheels of a shopping cart... would that be positive or negative camber?
