can't hook worth crap
Old May 23, 2007 | 10:37 PM
roosteracer's Avatar
Default can't hook worth crap
i have a heads and cam car with a 373 rear end gear also 4000 stall with 325 et streets and i still can't hook. i'm on a stock suspension lower control arms and shocks and so fourth. do you think i'm just not sending the power to the ground and thats why i'm just spinning them for like 30 ft.? even when i heat them up?
Old May 23, 2007 | 11:06 PM
DuronClocker's Avatar
Getting any wheelhop or just spinning? What kinds of tire pressures were you running?
Suspension-wise, I'd invest in a chassis-mounted adjustable torque arm and some LCAs to start with.
Old May 23, 2007 | 11:11 PM
no i'm just getting spinning and car getting loose in the rear. should i let pressure out of the tire? and how about shocks and springs? would that help that problem?
Old May 23, 2007 | 11:20 PM
How much pressure were you running in the tires, and what size are they? 325/50r15 or something around there?
Drag shocks/springs will obviously help, but the stock stuff isn't really that terrible.
If you want a few small, easy, cheap upgrades, get a poly torque arm mount, transmission mount, and swaybar mounts/endlinks. Could throw an air bag in the right rear spring too. That made a huge difference levelling my car out at the track last time. LCA bushings are good to get done too, but for the cost/time of putting new bushings in your old arms, you're almost better off just buying a basic set of non-adjustable poly/poly arms.
Old May 23, 2007 | 11:26 PM
i just checked and i have like 24 ponds in my right tire. yes they are 325 50 15 mickey tompsons
Old May 24, 2007 | 12:09 AM
staringback05's Avatar
Torque Arm.......
Old May 24, 2007 | 03:23 AM
OldeSkool's Avatar
a torque arm will only improve you if you go with a shorter than stock arm because that will put a little more "weight" on the back tires. otherwise, you'll keep on spinning.
Old May 24, 2007 | 10:08 AM
UCFWS6's Avatar
I run 13psi in my MT's but i get wheel hop, im hoping my new lca's with poly bushings helps. How are you launching? How much are you flashing the tc?
Old May 24, 2007 | 10:18 AM
2001z's Avatar
I would start lowering the pressure 2lbs at a time and see where the tire with your setup match the best. I like 18psi when running mine but some cars dont like that pressure.
Old May 24, 2007 | 12:04 PM
well i finally got my car all done and tuned and i threw on the mt's and i went out to race a sti last night and he got me from a dig since i just left 20 to 30 ft. strips but i got him after i finally hooked up. i had my 200 and something pound friend in the car also. first race i gave the trans brake like real low rpm and i just slipped. 2nd race was just me and i gave it a a little foot brake and i really didn't even give it any gas and again just didn't hook up. so somethings not right on the car i have a th400 with a stock torque arm.
Old May 24, 2007 | 12:06 PM
maybe some new race shocks?? i mean i am making the the power to the ground
Old May 24, 2007 | 11:14 PM
98TADRIVER's Avatar
adjustable shocks, LCAs, torque arm would all help. i could dead hook on the street in my M6 @ 3500rpm, on 245 50 16 nitto 555r's
