I searched and didnt find a clear answer please help!!!
I got 17x11 with 315's toms wheels Zr1's and I put on Vogtland springs that offer a 1.2 inch drop, when i put my wheels back on and lowered the car the wheels where jammed against the bump stops what can I do to get my wheels back on without hitting anything and be able to drive it. Please help and yes I did search just cant find a clear answer.
Thanks,
kenny
Thanks,
kenny
Wait, what? You're saying the car is on the ground and your wheels/tires are hitting the bumpstops?
Sounds more like you're trying to put the wheels on with the car jacked up by the frame rails. When you have 17x11 rims, you can't jack up the rear of the car by the frame rails anymore. You have to jack it up by the differential housing. Once you support the rearend, you can mount/dismount the rear wheels without the bumpstops interfering.
-Mike
-Mike
No other modifications besides rolled fender lips and longer studs. I can jack the car anywhere I want without anything touching / hitting anything else.
What size wheel spacer are you using?
That was a hint.....
