SLP 19mm Rear Sway Bar for 05 GTO
I just replaced my 16mm stock rear sway bar with a SLP 19mm. The installation could have been much easier if SLP didn't make you reuse the stock brackets that go over the bushings. Anyway my GTO no longer corners like an old pick-up truck. Traction has always been a problem with my 463 Lbs of torque. But the bigger sway bar made an inprovement here too. I highly recommend this product to all 04-06 GTO owners.
