Suspension Setup
Old May 3, 2003 | 08:54 AM
pharmpod's Avatar
Default Suspension Setup
What are your thoughts on running Koni DA's with stock springs on a convertible? I have a STB and SFC's. I have the 1LE kit which includes sway bars, phr, rear lca's.
Benny
Old May 3, 2003 | 09:39 AM
trackbird's Avatar
Default Re: Suspension Setup
SHocks can really improve the handling of a vehicle. It won't lower the car that way, but it would still be a nice improvement. Just my thoughts.
Old May 3, 2003 | 10:02 AM
pharmpod's Avatar
I am curious about the koni's on a convertible.
Someone told me that they are too hard and may cause
quarter panel dimples. I am not looking to lower the car, just firm it up.
Benny
Old May 3, 2003 | 11:35 AM
trackbird's Avatar
They can be adjusted from nearly stock to "ouch that's stiff". If you are really planning to stifen them up, you may want subframe connectors. But if you use a setting that is "correct" for stock springs, I doubt that you'll have any problems.
Old May 3, 2003 | 07:05 PM
pharmpod's Avatar
I have Don Goetz Industries 2 point bolt on subframe connectors for convertibles and a 2 point modified edelbrock shock tower brace.
Benny
Old May 4, 2003 | 08:47 PM
trackbird's Avatar
I don't suspect that you'll have any problems if you are running connectors and such. I doubt that you'll be running over 6-7 clicks of compression and less than 6 sweeps of rebound on the front and 1/3rd of a "turn" of rebound on the rear....actually, with stock springs, you'll probably not even be up to these settings and it is not that stiff (not to the point of abuse), it firms things up nicely, but I don't think you'll have a chance of "bending" anything. Good luck!
