?????LS1 calipers on my 93 F Body????
Old 06-24-2007, 07:20 PM
Rick. Salinas's Avatar
Lightbulb ?????LS1 calipers on my 93 F Body????
i want to upgrade my lt1 FRONT brakes to ls1 wil i need any kind of bracket?... i doubt the calipers will just directly bolt on... unless im wrong..
Old 06-24-2007, 10:45 PM
trackbird's Avatar
You'll need the spindles and all. The easiest way is to buy the complete setup from an LS1 (or 98 and up V6 car) and swap it. Take the brake hoses, the spindle, the rotor, caliper, pads and if you can get it, the metal tab that the brake hose clips into (that's bolted to the K-member), it's also different and unless you drill it out or go to braided lines, the stock LS1 hose won't fit in there. Then, just remove, replace and bleed. It's not a difficult swap, but you need all the parts.
Good luck!
Old 06-26-2007, 12:09 AM
thanks man i once was lost and now am found
