removing rear wheel stud
Old Jun 25, 2007 | 02:11 PM
1HOTZ's Avatar
Default removing rear wheel stud
One of my rear wheel studs is shot. I got a new one and I knocked the old one loose, but I can't get it out because of the plate behind it. Does anyone have any idea how to get that plate off, I think it might be part of the emergency brake assembly, but im not 100% sure.
Old Jun 26, 2007 | 06:55 PM
JL ws-6's Avatar
Race your car!
unbolt the plate. Pull the caliper and the rotor off, and you will see it's held on with 4 bolts. You can remove teh wheel sensor (4 channel car anyway) and once the sensor is out and the plate is unbolted, you can postion it to allow for the old stud to come out. I installed the long ARP studs that way, and had no problems.
Old Jun 27, 2007 | 01:14 AM
ohsofast's Avatar
Is it the same if you have a 12 bolt vs 10 bolt
Old Jun 27, 2007 | 04:37 AM
JL ws-6's Avatar
Race your car!
I have a 12 bolt... and I've changed a stud when I had the 10 bolt once too... same way.
