99 camaro shocks?
Shocks cannot keep you from bottoming out by themselves, spring rate is a serious issue there. I've never run the eibachs, but too low a rate + lowered = bottoming out.
If you have the prokit, I'm told its a 400lb front rate. You should be in good shape w quality shocks. But spend the $ here, because stock and cheap aftermarket shocks are not designed to handle lowering springs.
What I can say is I was hesitant to pay the coin for the Konis...it is up there...but now that I have, I will not waste $ on cheap shocks again...you really get what you pay for there. Many others would agree.
What can I say...great minds think alike. Trending Topics
A. He said "i am looking for real good handling and something to help me from bottoming out." Drag race set ups are not for good handling.
B. I posted the eibachs spring rate as 400lbs...stock is 292...so yeah, that would be higher than stock.
C. How will a softer shock help the bottoming out issue (or handling)?
If he IS looking for a drag race set up you may be correct...but thats not how I took his post.
*also I agree that the rear progressive springs do not qualify as high rate (80-137lbs) copared to stock 114lbs. To be honest this is probly responsible for any bottoming out.
1. Revavles.
2. Koni
QA1 are drag shocks and not the shocks you want with lowering springs on a DD.
