What happens if the rear brakes fail?
Is all brake pressure lost or will the others continue to operate? Picture the rear caliper breaking in two pieces on an LS1 F-body for this scenario.
On the flip side, can anything be done to prevent total loss of braking in the event of failure? If I remember right on my 5 liter Mustang, a brake proportioning valve would serve this purpose in addition to the adjustments.
Cars since the 60s have had dual-reservoir master cylinders. So if you lose pressure (via broken line, or caliper failure) you will still brake with the other pair(2 calipers on each of the 2 reservoirs).
