Wolfe anti roll vs Spohn Drag sway
I am kind of up in the air on this one. Wondering if the weight difference is enough to sway (no pun intended) my decision. I dont daily drive the car tho' I do drive it on the weekends. I have alot of weight reduction,K member, it's driven on Hoosier QTP's and skinnies. For the most part a fairly rough ride.
Looks like the Spohn would be alot heavier. I'm being real critical of weight as I am trying to drop as much out of the car as I can. I've recently removed the PS, wipers,wiper motor,cruise,TCS installed race buckets etc. You get the idea here so just would like some opinions as to wether I should just go with the Wolfe weld in setup. Thanks
