Help with bleeding brakes?
Old Jul 28, 2007 | 10:26 PM
deviate42's Avatar
Default Help with bleeding brakes?
So I just swapped out the pads on all 4's, and I guess I didn't bleed the brakes correctly.
I have to pump the petal to get any sort of brake feel, then it goes right to the floor. Lines are good, pads are new, and calipers were working fine before the install...I started from the RR and ended with the LF.
I don't have traction control and I had a person help me while they pumped the brakes and held them to the floor. I did this with the car off...don't know if that helps
Help me guys, I have work on Monday!!
Thanks
Old Jul 28, 2007 | 11:53 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Someone needs to write a brake bleeding sticky. You might want to check that the center sectio where the rear brake lines T off is firmly connected. When I first tried to bleed mine I realized that I hadn't tightened it enough and fluid was leeking.
Old Jul 29, 2007 | 01:13 AM
deviate42's Avatar
so far no leaks, the reservoir is topped off.
Old Jul 29, 2007 | 01:51 PM
BigDaddyBry's Avatar
Have you driven the car yet? Or are you just noticing the brake feel while sitting in the car in the driveway?
Old Jul 29, 2007 | 02:00 PM
Soul TKR's Avatar
start the car up, and at first you'll have no brakes... but pump em a good couple of times and if everything was done correctley, the brakes should come back...
Old Jul 29, 2007 | 08:11 PM
z28bryan's Avatar
Could you explain the procedure you did for bleeding the brakes?
Old Jul 30, 2007 | 11:53 PM
deviate42's Avatar
Thanks for the replies guys. Yeah I drove the car and I had to pump the brakes to get them to engage.
I think I ran out of fluid in the reservoir the first time i did it because I didn't top it off after bleeding each corner.
Now they are working great. I did everything again...
I just topped off the reservoir before I started a new corner. Began with right rear, ended with left front. I had air in the right front, all the others were fine. What a relief. The brakes feel great with the new Baer Rotors
