1le sway bar
Re: 1le sway bar
I have a 1LE Take Off front ASB w/bushings. No end links. It came from my '02 TA. I installed the Bilstein Suspension w/a different front ASB and the 1LE version is now excess to my needs. Email me off line if interested.
Regards
Steve
Regards
Steve
Re: 1le sway bar
'01's SS's come with a 32mm hollow sway bar; 1LE for this year is 35mm hollow. If you want a good front sway bar, get the BMR 32 mm solid bar; besides being solid, it is made out of stiffer steel.
Re: 1le sway bar
Re: 1le sway bar
According to SLP, they changed from a 32 hollow to a 35mm hollow front sway on the Bilstein option part way through '01. For a reference, build #2283 is 35mm.
Non-Bilstein SSs and Firehawks had the 32mm hollow, and I believe the 1LE bar is a 35mm hollow part. This is all according to a table I downloaded some time ago comparing the SS, Firehawk, 1LE, and Bilstein options.
I can't swear to the 1LE info, but the Bilstein info is correct.
BobP
BobP
