Stupid UMI Relocation brackets
I installed BMR LCA relocation brackets on my 10 bolt in about 20 minutes. From what I remember you do have to hammer them into place around that emergency cable bracket. I did not have to take anything else apart. And I'm sure it's nearly an identical product.
I know cutting this bracket isn't that big of a deal. Were just pissed that they don't tell you before hand that modifications are required. Some people don't want to cut on there car. Why can't they just say that on the web site and or the instructions. The install wasn't hard at all, but they say "UMI Performance's new bolt-in control arm relocation brackets are a 100% bolt in set-up that require no welding, drilling or cutting. They are a simple bolt on that can be completed in 30 minutes or less.". That's a complete lie. Yeah it is possible be done in 30 minutes, if you know before hand you need to cut and where. What don't they understand about cutting this bracket. I like the quality and customer service of UMI and will buy from them again, I just don't like when company's forget to tell you important info to better sell there products. I'm posting this incase anyone else comes into this problem considering there instructions don't state any of this. The Best V8 Stories One Small Block at Time
oh yeah, it took me maybe an hour, but that because i decided to do some other maintenance and whatnot including stripping the rear tires off of the rims to put new ones on
If you can't handle the simple install of a relocation bracket your in for some rough times modding the rest of your car.
See if this helps you out at all.
http://nitch.us/id30.htm
All aftermarket relocation brackets require the same modification. You PM'd for help and I replied quickly with a modified instruction sheet that helps explain what to do. What else can I do. We modified the instructions to help explain it better.
Thanks to everyone else for the positive comments, we appreciate it!
Ryan
Installing these brackets requires you to bend or cut your e-brake brackets
Would it have kept you from buying them if you knew that? If so, I'm not sure modding a car is a good hobby for you. It's not like they asked you to cut off your own toe.
-Mike
-Mike
