Unbearable vibration over 60mph after install of new parts
Set your pinion angle at 0 degrees, the yoke on the Moser doesn't react real good at those negative degrees.
Also a BIG contribute to this is your polyurethane mounts, especially the trans mount. If you want try putting the stock rubber one back in just to see the difference.
Hope that helps,
Ryan
Hope that helps,
Ryan
well i got under mine looking for the cause and the rear looks like it has the yolk pointing up towards the sky. i rember when i put on my ta i set the gauge on the ds and it was 1* to the left then i set it on the plate of the ta and it was 1* to the right but ill try the new way with geting the angle from the trans and adj my lca's
Hope that helps,
Ryan
Hope that helps,
Ryan
im gonna do this tomorrow at work on out hunter alinment rack. so step 1 put the angle finder on the pulley to get the angle of the trans. then put it on the flat part of my umi t/a get the angle the take the angle of the trans and subtract it from the rears angle?
Its the Poly Trans Mount you put it.
I had one put in on my car. Then my car started vibrating really really bad. I took the aftermarket trans mount out...and put my OEM one back in...and it was fine.
Theres always a sacrifice when you mod. Usually the better the handling and suspension, the worse the ride quality....unless you have a Ferrari that is.
well i got mine on the rack today
my d/s is -1.5* (from the trans it goes down ward)
now i set my rear 1-2* upwards positive
so my d/s angle of -1.5 add my rear angle of 1-2* and my pinion angle is about 1* positive?
and my pass ride lca was about 1 turn shorter then the other side. i still have some vibes but some is gone
I forgot to check my LCA lengths when I got them from UMI. They suppose to come factory length right? Side to side im pretty sure is about dead on I measured that once and my wheel gap is exactly the same on both sides.
#32
#35
ok im 100% confusied
my ds has a 1.5* slope pointed down (trans is higher the the rear)
so i need to make my rear point 1.5 up to get 0*?
No,If your pinion is at 0* you are actually at -1.5* of driveline angle.
#37
http://buickperformance.com/Pinion.htm
guys, it's not that hard to PROPERLY adjust your pinion angle so that you have roughly a 0° -driveline- angle, which is the correct way to set it up for no vibrations related to incorrect driveline angles.
#39
I think I may have bad tires. I jacked the car up a few inches and put it in gear. The rear tires were wobbling quite a bit. The wheels were straight, but the tires were wobbling all over. Going to replace those and see if it cures my vibration.
#40
I have the same issue with Moser 12 bolt and adjustable TA set at only -1 except it is at 100 MPH+. I think I will just adjust for zero, the Spohn arm solved my wheel hop issue, maybe it won't hop at zero either and the vibration will also stop.
