35 mm Sway Bar
35 mm Sway Bar
Where can I get a 35 mm front sway bar for a 99 Trans AM? Is it a solid peice or hollow? How does it compare to the BMR 32mm solid peice? I have BMRs lowering springs, panhards, and Engine strut Bar. I am looking to continue building my suspension....Sway bars next? or Subframe connectors? Thanks
Re: 35 mm Sway Bar
You can get the suspension techniques 35mm solid front sway bar from Sam Strano. It makes the car even more rigid & have less body roll in turns. Made a big difference from my stock 32mm hollow bar. It weighs a ton though.
Re: 35 mm Sway Bar
Swaybars then subframe; doesn't matter much. I did subframes first, helped tremendously. The only reason you should worry about the 35mm with weight is if you're hardcore drag racing; you can remove it for track runs. IMHO.
" It makes the car even more rigid & have less body roll in turns."
Sam will explain this in a call. He's OOT till Wednesday though.
