How to replace rotors and pads?
Old Aug 16, 2007 | 11:56 PM
transamws6_97's Avatar
Default How to replace rotors and pads?
Ok so I've never had to do my brakes yet but it is now time to do brakes. So if someone could throw a link in here to show me how to put new rotors on and replace my pads that would be great thanks
Old Aug 17, 2007 | 07:59 AM
z28bryan's Avatar
www.installuniversity.com
Old Aug 17, 2007 | 11:02 AM
tylerdj's Avatar
Remove your wheels/tires. Remove the 2 bolts on the inside of the caliper. Remove pads and rotors. Replace pads and rotors (may need to spread the pads some fit back onto the new rotors). Replace and tighten 2 bolts on inside of calipers and put wheels/tires back on.
Old Aug 17, 2007 | 12:35 PM
z28bryan's Avatar
Cleaning the caliper guide pins and regreasing them wouldn't be a bad idea while you have the caliper off.
If your car is pretty old, it might also be worth it to get the disc brake hardware kit. Its like 20 bucks for fronts or rears and replaces the black boots that go over the caliper pins, the metal pad shims, and the anti rattle clip
Old Aug 17, 2007 | 12:37 PM
suburbanlife866's Avatar
yea just follow the installuniversity.com directions. I had never done a break job before, used their guide, and everything went fine
Old Aug 17, 2007 | 12:57 PM
Thanks guys I definitely will be using that install university guide to help me out. I think I will get that disk brake kit since my car is 10 years old
Old Aug 17, 2007 | 03:58 PM
Z28LS1camaroguy's Avatar
Its easy just like stated above do all that is stated in the guide and you should be fine, may want some C clamps to push the selinoids back and also make sure that the pins that compress the brakes move freely and arent stuck or you will have problems.
Old Aug 19, 2007 | 05:52 PM
ghardester's Avatar
Get the brake kit that has the little clips and rubber boots. Not expensive. Get a big C clamp to push the pistons back into the calipers. That makes for easy removal and instalation. Grease the guide pins. The rest is just unhook, bolt back up. Be sure to use a tourque wrench when you put things back together.
Old Aug 19, 2007 | 06:31 PM
davered00ss's Avatar
Moderator
I just did the front & rear on my car. It's prety straight forward. If you need help go to www.installuniversity.com I think they have the complete write up.
