Front ball joint question
Old Aug 27, 2007 | 03:12 PM
95GreenZ28's Avatar
Exclamation Front ball joint question
Ok I am trying to put my spindles back onto my lower ball joints and when I go to tighten the nut down it is all spinning. Does this mean I need to replace the ball joint or is there a way to hwold it while I tighten the nut down? Thanks in advance guys
Old Aug 29, 2007 | 05:55 PM
trackbird's Avatar
Usually I just set them onto the balljoint with a big socket and a rubber mallet. The pin in the balljoint is tapered and once you get it "stuck" (don't beat it to death, just a quick whack to set the spindle down onto the pin should do it), you should be able to install the nut.
Sorry for the delay, I just found this post.
