Question about brake fluid?
Old Aug 31, 2007 | 12:07 PM
01 Sunset SS's Avatar
Default Question about brake fluid?
Hope you can help me out. I know that DOT 3 or 4 brake fluid is compatible with our cars. Is the DOT 5 fluid compatible? My dealer tech said 3 or 4 only. I have a 2002 Pontiac Trans Am Ws6 with a stock brake system now. I have new pads, rotors, and stainless lines ready to go in after a complete flush. Also how much brake fluid do I need to get to fill the system up?
Thanks
Old Aug 31, 2007 | 12:36 PM
coolformula's Avatar
My understanding is Dot 5 is NOT, but 5.1 IS. But i'm sure some more people will ring in. Also SEARCH has tons.
If you bleed it all 2 big bottles should be good.
Old Sep 1, 2007 | 01:55 PM
dailydriver's Avatar
^^^^ RIGHT!! DOT 5 is silicone based fluid. YOU WILL RUIN YOUR BRAKE SYSTEM IF YOU USE THIS!! The DOT 5.1 is fine, but I would flush the whole system thoroughly if you must use it.
Personally, I would just use one of the good DOT 3/4s available (there are MANY!!!).
Old Sep 1, 2007 | 05:59 PM
Black Hawk's Avatar
Get some ATE super blue racing fluid, it seems to get a lot of praise around here.
http://www.tirerack.com/brakes/ate/a...UPERBLUE_Qty=1
Old Sep 3, 2007 | 07:22 PM
VIP1's Avatar
Copy & Paste Moderator
Check out this white paper on brake fluid:
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
(BTW, its also in the Brake FAQ in the StopTech white papers link.)
