Torque Arm Install Questions
Old May 28, 2003 | 06:42 PM
LIL SS's Avatar
Moderator
Default Torque Arm Install Questions
I was thinking about trying to install my TA tonight. Couple questions..
1) Are there any special requirements for a TA install? (Don't see anything on install university)
2) Is Lock tight required on the bolts?
3) What do the bolt's need to be torqued to?
4) Aprox time for install?
Old May 28, 2003 | 09:51 PM
glitch77's Avatar
Default Re: Torque Arm Install Questions
Torque Arm Replacement
Removal Procedure
Important:
When raising the vehicle, support the vehicle by the frame, allowing the suspension to fully extend (unloaded).
1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Support the rear axle (1) with an adjustable lifting device.
3. Remove the torque arm from the propeller shaft, if equipped with two-piece propeller shaft.
4. Remove the bolts and screws (2), the washers (3) and the nuts (4) from the rear axle (1).
5. Remove the bolts and screws (3, 7 and 8) and the nuts (5) from the automatic transmission, if equipped.
6. Remove the outer bracket (9).
7. Remove the inner bracket (10).
8. Remove the torque arm (6).
Installation Procedure
1. Position the inner bracket (2) through the transmission.
2. Position the outer bracket (3) to the inner bracket (2) and loosely install the nuts (7) and the bolts and screws (5 and 6).
3. Insert the torque arm (4) into the brackets (2 and 3).
Notice:
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
4. Install the nuts (7) and the bolts and screws (5 and 6). Tighten
Tighten the nuts (7) to 41 N·m (30 lb ft).
Tighten the bolts and screws (6) to 50 N·m (37 lb ft).
Tighten the bolts and screws (5) to 27 N·m (20 lb ft).
5. Position the torque arm (5) to the rear axle (1).
6. Install the bolts and screws (2), the washers (3) and the nuts (4). Tighten
Tighten the nuts (25) to 132 N·m (97 lb ft).
7. Install the torque arm to the propeller shaft, if equipped with a two piece propeller shaft. Refer to Propeller Shaft Replacement - One Piece or Propeller Shaft Replacement - Two Piece in Propeller Shaft.
8. Install the rear axle support.
9. Lower the vehicle.
Old May 28, 2003 | 10:46 PM
LIL SS's Avatar
Moderator
Thanks a Ton..
Old May 29, 2003 | 06:58 AM
glitch77's Avatar
No problem...
