PA Racing k-member w/a-arms,anyone using them?
Im installing my new engine and turbo kit this week along with the pa frt end kit. It includes their k-member with upper and lower a-arms. Has anyone used these . Any weird problems i should be prepaired for.
Thanks
Alex
Thanks
Alex
Yea bolts get the bolt kit depending what it includes. If you don't read the stuff below.
Going to need a metric shorter bolts and washers for the first 4 holes that connect into the frame. The stock member has like 5 inch bolts. Get like a 2 or 3 inch bolt.
Get bolts, washers, lock washers and nuts for the Motor perches.. Going to need 8 total of each. If you keep your stock perches just remove the 4 stock K bolts and leave the perches hang. Then line up the perches to the PA K member. If you do remove your mounts or perches don't tighten the perch bolts on the K until you get the bolt through the perch and motor mount.
Make sure you have both Castle nuts for the ball joints on the A-arms guy I got mine from I only had one and they won't take the stock ones. The stock upper and lower bolts and nuts will work for attaching them to the K member.
Going to need bolts/nuts for the shocks as well. We had to use a washer underneath the shock as well otherwise it would bottom out on the mount. See pics below.
Rack takes the stock bolts.
Motor perches. Get the light ones... I thought mine came with perches and it didn't and I had to reuse the stockers.. and there heavy ***...
Greese Zirks. Get them.... Can't remember the size off hand but its 45 by something..
PA sells a bolt kit I am not sure what is in it but I would find out will save you lots of trips to the bolt store.
How to adjust the a arms so there close. I have NO clue I will find out what kinda job we did when I get it aligned. Probably will cost bit $$$ to get it right. Make sure your steering wheel is half *** straight when you put the rack back up.
Another thing the install is a pain in the ***. Good Luck..
Here is some pics I posted on a local site.
PA k vs, Stock. and yes I work on cars in my sandals.
![](http://i27.photobucket.com/albums/c165/paulq1319361/IMG_0743.jpg)
Coil overs, still working on ride height.
![](http://i27.photobucket.com/albums/c165/paulq1319361/IMG_0750.jpg)
Fastkeen doing the dirty...
![](http://i27.photobucket.com/albums/c165/paulq1319361/IMG_0764.jpg)
Almost done
![](http://i27.photobucket.com/albums/c165/paulq1319361/IMG_0762.jpg)
Kinda done didn't take pics after this cause I wanted to get it on the road.
![](http://i27.photobucket.com/albums/c165/paulq1319361/IMG_0767.jpg)
![](http://i27.photobucket.com/albums/c165/paulq1319361/IMG_0735.jpg)
Lucky these things are strong and light otherwise I would have taken the dang thing off and threw it in the garbage and got a UMI like I prob should of done in the first place. Now it if it does break I will be one mad ****.
Good Luck
Almost done
Good Luck
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
