More BMR...
Old May 31, 2003 | 09:58 AM
Rice Burner's Avatar
Default More BMR...
I have the lowering springs, panhard, engine strut bar, and LCAs. Anyways, I can get a set of adjustable BMR upper control arms, brand new, for very cheap. What changes will I see once these are on, and what type of adjustments are recommended? Thanks.
Old May 31, 2003 | 11:28 AM
2001CamaroGuy's Avatar
Default Re: More BMR...
upper control arms? 3rd/4th gens don't have upper control arms.....do you mean a-arms (front suspention)?
panhards.....plural..... ...sure you don't mean LCAs (lower control arms......)...the bars that go forward from the bottom of the rear end and connect to it to the car?
a rear bar that goes diagnoly across the rear end
thats the panhard rod
It will be a little stiffer (more responsive) but not a lot. LG motorsports explained that the lower a-arm is the one that really makes a big difference. It is the one that really carries all the load, the upper a-arm is basically along for the ride.
Every piece of my suspention had been changed (LCAs, the panhard rod, the K-member, the lower a-arms, and the torque arm....I even have subframe connectors and a roll bar) EXCEPT for the upper a-arm. Just this past week I installed BMR's race (rod end version) upper a-arm and the car feels exactly like it did before..... ...go figure.....$250 and no change.....
So...I don't know....it depends on HOW cheap you are getting them for.....
hope that helps
Chris
Old May 31, 2003 | 12:10 PM
Wow thanks for the correct info, I now feel retarded. Thanks a lot!
Old Jun 1, 2003 | 07:25 PM
its ok....you just got the names backwards....it happens
Old Jun 6, 2003 | 07:36 PM
redz_02's Avatar
upper control arms? We don't drive mustangs . Anyways, i would go tubular k member before a arms.
Old Jun 7, 2003 | 07:26 AM
BADZ's Avatar
Moderator
https://ls1tech.com/threads/showflat...14&fpart=1
There are a few good pics here..
