Using C5 Rotors on F-Body LS1 Calipers - Can it be done & what is involved??
I read in the brake faq that these rotors are 13" as opposed to stock 12". faq makes it sound like one can use the bigger rotors on the stock fbody calipers?
What would be the benefits of running a bigger rotor?
will these fit under 17" wheels?
Copy & Paste Moderator
You need an adapter to move the caliper further outward to fit the larger rotor. If you do some searching (or check out some sponsors, ex: UMI & LG) you'll find more info.
