Can anyone identify my problem???
Old Oct 3, 2007 | 03:21 AM
Tirefire's Avatar
Default Can anyone identify my problem???
I've had my car for over a year now since I went FI and installed my 9 inch rear-end. The problem I have with the car is that every time I run into some bumps or I am slowing down, the rear end starts to smack the hell out of the underside (bottoms out) . Would replacing my 94,000 miles original shocks help any or is my 9 inch to heavy for my factory springs and shocks. Any help is greatly appreciated.
Old Oct 3, 2007 | 03:25 AM
Tirefire's Avatar
One other thing I have a Spohn torque arm and I'm wondering if that has anything to do with the bottoming out as well??
Old Oct 3, 2007 | 06:38 AM
BlackScreaminMachine's Avatar
Internet Mechanic
is the body of the car hitting, or the exhaust?? Most Tq arms need modifying. But what I would do is get under the car check for "wear" spots, signs of hitting, on the rear. I would 1st see what the top of the tq arm looks like, my BMR/moser 12 bolt had a issue hitting the rear seat belt bolts and rubbing bad, made a horrible popping noise when I turned.
Old Oct 3, 2007 | 07:26 AM
JD_AMG's Avatar
What springs are you on?
Old Oct 3, 2007 | 08:43 AM
Tirefire's Avatar
Actually, the rear-end is hitting the body to the point that it has dented the top portion of where the 9 inch sits. I currently have all stock suspension.
Old Oct 3, 2007 | 12:51 PM
JD_AMG's Avatar
Did you remove the bump stops?
Old Oct 3, 2007 | 12:52 PM
Nix_WS7's Avatar
I'm willing to bet your Springs and Shocks are done dude. Open the Hatch and have a few buddies stand inside where the t- tops go and have them jump up and down while you are looking under the car. If the top of the carrier hits the under body its a safe bet to say time for new springs and shocks.
Old Oct 3, 2007 | 01:23 PM
Sam Strano's Avatar
LS1TECH Sponsor
Bumpstops need to be there. If they aren't, that's issue 1. Issue 2 are the shocks. They aren't controlling the unsprung weight (which is the axle), and sounds like it's just getting out of control when you hit bumps or the rear of the car is lightly loaded. Compression damping is what controls unsprung weight's speed of movement.
__________________
Old Oct 3, 2007 | 01:59 PM
Greggy's Avatar
+1 sam
Old Oct 4, 2007 | 02:19 AM
Tirefire's Avatar
Thanks for the help guys. Sam I've been looking at the GMHTP article (Street car, Track car) and their using the Strano 550/150 springs and the koni single adjustable 4/3 shocks, is this a good setup for me?? I really don't want my car to drop more than an inch could you give me any advise that might help with my problem. One other thing my car sees the track about twelve times a year and is mostly driven on my days off. Thanks Andy
Old Oct 4, 2007 | 02:20 AM
Tirefire's Avatar
Sam could you also quote me on a price for shocks and srings.. Thanks
Old Oct 4, 2007 | 02:21 AM
Tirefire's Avatar
Old Oct 6, 2007 | 03:34 PM
Tirefire's Avatar
Sam, any help greatly appreciated.
Old Oct 6, 2007 | 04:04 PM
JD_AMG's Avatar
Call him : stranoparts.com.
