Bleeder screw issues, need help.
We didnt lose much fluid so that all went well.
When we went to bleed the brakes I was using a 10mm line wrench the fittings were very much tight and I fear rounding them off.... I spoke with a chevy tech who is my best bud and they used the GM fluid thats like liquid wrench/pb blaster.
Anyone here have this issue, and if you did, what did you do and if you broke it what happend after that....
oh BTW the Line lock does killer smokey burnouts.
good enough. Brake fluid seems not to have let them rust in on
my POS '68 El Camino (while the lines have rusted through, from
the outside, I replaced both of them after hard-braking blowouts
this year).
Rust eater type stuff is OK but maybe not needed.
One trick I use, is to tighten first. Just to break the rust bind if
any. That way if you round it, you're not rounding the edge that
you need for backing out. As long as you quit before it yields
totally, at least.
But I've worked on plenty of crusty brakes and don't recall ever
having a bleeder that was seized. Certainly not on a 5 year old.
as for the reason why its so tight, the car was a Boston car and I have rust and **** in lil places that I thought was never possible, so it doesnt suprise me about this.
