anybody try these?
http://www.ws6project.com/user_stor/...5bff12a3e6bd14
have you read the sticky at the top of the forum? slotted and drilled hurts braking performance and durability.
The brake fade that the one gentleman eliminated would be pads. I bet he changed pads at the same time, and pads fade, rotors do not. And better pads make life easier on any rotor. Faded pads create more and more heat which is put into the rotor. Why? Because faded pads don't stop. You then pound on the brakes harder and longer and that builds more heat. Rotors are heat sinks, and the more mass there is, the better that heat is absorbed.
I have no doubt THEBRAD has better brakes. I just don't agree that it's because of the rotors being drilled or slotted. Could be because the rotors weren't glazed, or from better pads.....
Most race cars do not use drilled rotors because that's metal that you're missing and can't contact the brake pad--it's like running smaller pads. Racing cars do use slotted rotors, but that's for gassing, and gassing is a race pad thing that happens when things get so hot the rotors glow red. Race cars don't usually have power brakes, and any gas boundary layer hurts the amount of force you can apply through the pads to the discs.
YMMV. Simply a matter of physics. Again, I don't doubt the car stops better. I disagree about why it does.
