Ideal street/strip suspension setup? not your average...
First off, i want to set some background here.
2000 stripper formula m6
The car is my fun/weekend car. I drive it on the street as well as the track.
We are ordering a Moser 9inch this next week.
I want to do a mini-tub so i can fit a 14inch wide tire on the back.
I had afew ?'s on suspension setup.
1.) would a 14inch tire interfere with the control arms?
2.) would there be a better place (for traction) to move the control arms
3.) what control arms, springs, shocks, torque arm, rear sway, etc. would you advise for perfect traction?
anything else you want to offer would be great.
thanks guys..
matt
thanks guys..
matt
Metco Control Arms with relocation Brackets put in middle hole
Hals shocks front and back with Hal front drag springs
Random Technology Torque Arm pinion set -2 or -3
Slicks of your choosing for wheel size
Removal of front sway bar
skinnies up front of course for track
front end weight removal
Subframe connectors
Just getting you started. I would buy most light components as possible within your budget. Of course get the car as light as possible. I keep my car full interior because I drive mine on street and at the track. Cheers and good luck.
Subframe connectors
If you mini tub your car you may as well just do a 4 link. I'm not realy sure cuz im not lookin under my car right now but none of the factory stuff is gonna work other then your torque arm. The control arms are already close to the tires and if you go with a wider tire that you want to tuck up into the fender well it may come in contact with the ends of the panhard rod. My nova runs 14" tires and its close between the tires....granted novas are narrow cars. Personally i wouldnt mini tub a new car and pay for all the custom work when there are guys runnin 8's in a stock fenderwell 11" tire car. If you do decide to go this route good luck with it.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
Thanks..
i was looking under there alittle closer, and it does seem a bit un realistic...im still gonna see what we can do, but...
we'll find out
edit: *** that. shoulda thought that one out before i decided it would be a good idea
just need to 'fit' a 11.5inch slick on there.....
we'll find out
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
