Line Lock wiring????
Old Oct 17, 2007 | 10:04 PM
Mike101's Avatar
Default Line Lock wiring????
It is an SLP line lock and the instructions don't tell me which wire goes on the top connector and which on the bottom. One is a switch wire and the other is the power. Which one on top???
Thanks Mike
Old Oct 17, 2007 | 10:15 PM
Duffster's Avatar
test the positive to one and the ground to the other. . . if it goes to the wrong direction (solenoid), simply switch them. Won't hurt.
Old Oct 18, 2007 | 07:48 AM
Mike101's Avatar
haha yeah I guess if push comes to shove I can try that but im looking for a more actual answer maybe someone that has one of these and can just go look at theres.
Thanks though
Old Oct 18, 2007 | 08:13 AM
ghettocruiser's Avatar
Im not 100% what you are asking about... Are you talking about solenoid wiring or switch wiring?
In either case, you cant hook up a solenoid wrong. It cant go backwards... Either wire on the solenoid should work either way.
As for wiring the system, there are some threads floating around on how to properly hook up line locks.
For a very basic "SLP" wire up, you want a positive wire, going into a switch, then from the switch to one of the solenoid wires, then the other sol. wire to ground. That will give you action in the solenoid. If you are using a lighted switch, then you need to just follow the switch wiring directions. If you arent using a lighted switch, it doesnt matter which terminal does what. You cant get them backwards.
For a SAFER better way to hook up the system, you will want to put a momentary switch inline with the system activation switch. You will go from 12v, to "arming" toggle switch, then to a pushbutton momentary switch, then to the solenoid etc etc.
So you can arm it...then activate it with the push button. Let go of the button...system turns off.
If you need more help than that...give us some more info on what you are trying to hook up.
Good luck!
Justin
Old Oct 18, 2007 | 10:09 AM
Duffster's Avatar
and use a relay to reduce the current flow through your switch such that you've only got activation current going through it.
As for an actual answer, it's a solenoid. . .it either works or it doesn't. Won't hurt jack or squat.
Old Oct 18, 2007 | 10:28 AM
Right...forgot to mention using a relay. Would have been too complicated to write out anyway haha.
I dont run a relay with mine, because I rarely use it. And its only momentary. I figured the reverse lockout solenoid doesnt use one...so I never installed it.
J.
Old Oct 18, 2007 | 12:28 PM
XX11SECZXX's Avatar
i was going to buy an slp linelock for my car, but it says it fits 87-92 camaros what is the difference on an 86? are the lines different?
Old Oct 19, 2007 | 08:43 AM
01bad ss's Avatar
Just looked at mine,I got the fused power wire to the top and the switch wire on the bottom.
Old Oct 19, 2007 | 10:40 AM
Mike101's Avatar
^^^ Thanks that exactly what I needed short and sweet!
Old Oct 20, 2007 | 09:54 PM
mcamarols1's Avatar
thats how i did mine
