Strut Mount Question...
Old Nov 3, 2007 | 11:18 AM
my01ws6's Avatar
Default Strut Mount Question...
Hey Im getting ready to put on new shocks and springs....My buddy who is helping me said I need to buy new Strut Mounts...is this true?
Car has 65k on it. He hasnt seen the old ones or anything he just says I need them.
Im installing Bilsteins and Eibach springs BTW.
Old Nov 3, 2007 | 11:46 AM
rekless's Avatar
they start to squeak after awhile...you dont NEED them but theyre a good idea
Old Nov 3, 2007 | 01:01 PM
Bow94z's Avatar
i dont think it's nessacary, i just reused my stock 145Kmile ones when i put springs on my car with no problems
Old Nov 3, 2007 | 09:45 PM
my01ws6's Avatar
hmmmm.....would it ride better? Or offer any benefits?
Old Nov 3, 2007 | 11:07 PM
z28bryan's Avatar
Sometimes the nut gets stuck to the shock mount. It's a common problem wtih a lot of cars. I'm still using my stock mounts and I changed my shocks/springs combo twice.
Old Nov 3, 2007 | 11:35 PM
ONEBADASSWS6's Avatar
I would definitely replace the mounts when you change the struts. They are rubber and wear out, better safe than sorry.
You can pick the stock ones up from Autozone for about $45 a piece.
Old Nov 4, 2007 | 01:13 AM
my01ws6's Avatar
Would there be any reason so go with aftermartket ones? Like KYB? The ones at my work (Advance Auto) are Monroe ($85/each) or KYB ($75/each)
Old Nov 5, 2007 | 12:36 AM
my01ws6's Avatar
anyone?
Old Nov 5, 2007 | 08:53 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I haven't seen one particular brand to be that different from another. I would go with what you can get at the best price
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Nov 5, 2007 | 11:05 AM
Greggy's Avatar
The shock mounts on these cars hold up much better than the front strut cars I have seen. If you use the large washer below the shock mount and the dogbone piece above the rubber is not that stressed. As with all rubber it does age though. I did not change mine out. (100kmiles) They looked good.
Old Nov 5, 2007 | 08:51 PM
bearcatt's Avatar
How ironic, I just installed my new Koni shocks, Strano Sway Bars and new brakes all the way around, this last weekend.
This is the reason why some of us end up replacing the strut mounts.
http://fla-thirdgen.org/shockreplacement.htm
After 74000 miles, my old shock nuts weren't rusted.
I ended up replacing the old strut mounts anyways because I bought them
ahead of time, just in case my old ones were rusted. I didn't want to
be in the middle of the install and have to deal with ordering those parts.
Hope that helps.
Old Nov 6, 2007 | 10:39 AM
Greggy's Avatar
I hope you replace the strut mount, large washer and dogbone piece in that case.
