Nasty wheel hop!
Nasty wheel hop!
The second i lose traction i get rediculous wheel hop. The only non adjustable element of my suspension is my panhard bar. anyone have any tips? Will adjusting my torque arm help any?
2 things jump out at me...one: Do you have lca relocation brackets to correct the lca angles thrown off by the lowering springs? and two: I have not heard good things about the KYB adjustable shocks...
I'm betting that if you don't have the relocation brackets thats the cause of your wheel hop...Lowering the car moves the front mounting point of the lcas lower than the rear mounts which unloads the suspension and will cause wheel hop...You want the front of the lcas to be higher than the rears...
--Alan
--Alan
Well I baught the car with all this **** on it, and i wouldn't be able to recognize the brackets because i've never owned an f-body with a 12 bolt in it. i just crawled under it and noticed that theres a set of holes just above the bolt that the lca's are mounted with to the rearend. is that it, or would it be obvious?
Having the lcas angled upward like has its cons though as well as its pros. If you are turning then the suspension geometry I've heard tends to slightly point the rear axle out making the car more tail happy. This is a problem for autox or road race drivers but wouldn't be an issue for drag racers. I use my car for autox/racing that involves turns so I am not doing lca brackets.
Also, the KYB shocks I've heard aren't up to par with lowering springs to control them properly. I don't have my own experience or evidence, but basically if your car wants to squat and your spring doesn't have enough control by the shocks, it will want to bounce back faster than it should, and multiple times. I would imagine that between a set of shocks that dampen the springs and a set that doesn't, that you would get more wheel hop with the set that doesn't control the spring as well.
