LCA Relocation Brackets?
Old Nov 8, 2007 | 09:44 PM
Zero4488's Avatar
Restricted User
Default LCA Relocation Brackets?
As of now I have the following Spohn components and I was wondering if it's worth getting the relocation brackets or just leave my suspension as is....
Torque Arm
Lower Control Arms
Pan Hard Rod
Sub-Frame Connectors
Old Nov 8, 2007 | 09:50 PM
djsanchez2's Avatar
Why not get them? It will add a lil extra bit during launches. I know it did with my car. I'm lowered so it was a DRAMATIC difference for my car.
Old Nov 8, 2007 | 10:18 PM
bigdsz's Avatar
My wheel hop was so bad I thought the car was going to fall apart. I got some UMI weld in relocation brackets, no more wheel hop ever, ZERO. The only bitch was putting the car up on jack stands and welding upside down. Don't get the bolt in ones by the way.
Old Nov 9, 2007 | 12:49 AM
Zero4488's Avatar
Restricted User
alright...thanks alot...next mod will be the relocation brackets...any particular brand???
Old Nov 9, 2007 | 03:42 AM
SIC LSX's Avatar
Fu*c Spohn get UMI! I have the bolton ones and they were great
Old Nov 9, 2007 | 08:18 AM
UMI Performance's Avatar
Hello, we offer both a bolt in model and a weld in model. Please take a look at the link below and if you have any questions please ask. You will also find our prices very competive.
http://www.umiperformance.com/produc...ategory_id=125
Thank you!
Ryan
Old Nov 9, 2007 | 08:57 AM
98camarossturbo's Avatar
anyone know will the bolt on ones work with a s60 rear?
Old Nov 9, 2007 | 09:05 AM
We have not personally tried but we have had many reports from customers saying our bolt on brackets work on Strange brand rear end's with no issues.
Old Nov 9, 2007 | 09:07 AM
thanks!
Old Nov 9, 2007 | 10:01 AM
Zero4488's Avatar
Restricted User
Alrighty...I'll check out UMI....
Old Nov 10, 2007 | 12:17 AM
chrismorales75's Avatar
Make your own relocation brackets, most after market ones only have two holes which don't give much adjustment, use thicker metal plate and drill the holes closer together you can get at least 4-5 holes from the stock location to the bottom hole.
Old Nov 10, 2007 | 12:26 AM
djsanchez2's Avatar
UMI here. ^^Or that idea works....
Old Nov 10, 2007 | 05:03 PM
Zero4488's Avatar
Restricted User
Well I'll look into a few different ones and I'll make a descision....
Old Nov 10, 2007 | 05:40 PM
junior28570's Avatar
I have them on my S60 ... no issues, they bolt right up
As for the posters question .. I consider LCA relocation brackets a MUST for being able to tune your susp.
