E Brake adjustments
my e brake, I have to pull it out to the very last adjustment to get it to engage,
I checked the little pads in the drum and they seem okay, any one the preferred method of taking the slack out this thing? It all seems to be in the actual handle itself. Also my brake light stays on, anyone have that same problem? Thanks.
https://ls1tech.com/forums/showthrea...y+brake&page=1
This was learned 25 years ago.
As far as the BRAKE light goes, yeah see that is what happened, I bled the brakes down and then the light came on because I didn't refill it right away (oops) and the next time I went to go drive it, I filled it up and it still won't go off. Should I just pull the battery cables and let it reset? Other than that I'm not sure how to get it undone.
