BMR XTREME Rear Anti-Roll Bar worth it?
CARTEK Racing
If I already have a Suspension Techniques 25mm solid sway bar with polyurethane bushings and the car does launch strait, with the front wheels an equal distance from the ground wile in the air, is it worth anything in added traction, better 60' and ET to switch to the BMW Anti roll bar or any similar bar?
Also, along the same lines, if I already have BMR tubular, non-adjustable LCA's with polyurethane bushings, is it worth swapping to solid mount, adjustable LCA's?
Thanks guys!
Thanks guys!
LS1Tech Premium Sponsor
If the car is already tracking straight you probably are not see much of a gain.
Lee Spicher
leespicher@yahoo.com
(813)986-9302
Lee Spicher
(813)986-9302
