relocation brackets for a moser 12 bolt
Old Jun 23, 2003 | 04:29 PM
2001TA's Avatar
Default relocation brackets for a moser 12 bolt
Which lca relocation brackets will fit a moser 12 bolt?
Old Jun 23, 2003 | 07:44 PM
vetteemt's Avatar
Default Re: relocation brackets for a moser 12 bolt
Here yea go Spohn makes them
Lower Control Arm Relocation Brackets - Moser Rear
Price:$85.00
Item #210-M
**Click on thumbnail photo to view a full-size image**
NEW DESIGN - These new Part #210-M LCA Relocation Brackets are designed to be an exact fit on any Moser Engineering 12 bolt or 9" rear housing.
Repositions your instant center by lowering your control arm angle for increased traction and anti-squat. Lowers rear of control arm up to 3".
This product is a must for lowered vehicles to correct your suspension geometry. Lowering your vehicle alters the LCA angle putting the rear of the LCA higher than the front of the LCA, this causes massive wheel hop and traction loss.
NON-LOWERED vehicles will also see a dramatic increase in traction by lowering the rearward angle of the LCA with our relocation brackets. The lower mount holes are placed in the arc pattern of the OEM length LCA. Therefore allowing a non-lowered F-Body to drop the rear LCA angle and NOT require a longer than OEM LCA. All geometry is correctly maintained. The anti-squat performance is providing most users with a full .10 or better 60' reduction!
Brackets are Laser-Cut from 3/16" cold rolled steel using state-of-the-art CAD/CAM technology for precision tolerances.
Must be welded into place. All Grade 8 hardware is included. Since the brackets must be welded in place, we ship them bare. Weld in LCA Relocation Brackets are the only SAFE and EFFECTIVE way to install them.
Part #210-M: $85.00 (plus shipping)
NOTE: These Part #210-M relocation brackets are designed specifically for usage on a Moser Engineering Ford 9" or 12 bolt rear housing. They will NOT work on a stock rear or a Strange Engineering 12 bolt rear housing, use Part #210-S for those applications.
Old Jun 24, 2003 | 08:57 PM
2001TA's Avatar
thanks
