No spanner wrench... any other way to adjust HAL height??
Had Speed Inc throw on a set of HAL's on the front of my ride when I had the new shortblock installed, but they forgot to get me a spanner wrench. They've ordered one for me, but it hasn't come in yet...
Anyone have any other method(s) for adjusting the spring perch/ride height???
TIA
TIA
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Take a flat blade screw driver,put it in the indincation in the height adjuster, and hit the screw driver with a hammer. This will mess up your little notches some but if it needs to be adjusted now, thats how to do it. its a lot easier to do with the wheels in the air(less load on the springs).
I used real big channel locks on mine and it works just fine. Also, put a little grease on shock to help adjust it and turns a little easier. When you get the spanner wrench, weld a iron piece to it for more leverage, what they send it junk. Cheers..........
use flat 1/8" stock..steel...and grind it away so there is a notch in it like the spanner..will work better, no swivel
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
