my brakes stuck on
my brakes stuck on
yeah, so today while driving my brakes somehow stuck on a bit, heated up and the fluid started expanding, pressing the pads against the rotor.. it got to the point where i had to burn the clutch up and started spinning the tires to move
i think i have fixed the problem, but im just wondering if i should look for anything or do anything after this happened.. just as a precaution.
do you guys think i am fine, or should check anything, etc.
thanks!
thanks!
the brake light switch pressed up against the pedal, i drove for about 5 miles, and then my car felt like it was loosing power, i pulled into a parts store and when i stopped to park, my brakes were almost fully stuck on, i was burning my clutch up in first and spinning the wheels.
after being in the parts store for a few min the brakes started working again and i pulled the switch out
