Replace shocks
Old Dec 7, 2007 | 02:17 PM
BurtReynolds's Avatar
Default Replace shocks
My car has 106 K I do not plan on lowering it. I was wondering if i could get away with just purchasing the rear shocks. Ive been reading on this board and everybody says Koni sa. How much are they.I wiil also be using the stock springs
Old Dec 7, 2007 | 03:02 PM
JScamaro's Avatar
Koni's range from $740-$848 a set from Sam Strano.
http://www.stranoparts.com/searchbym...D=20&ModelID=7
I would keep saving until you can buy all 4.
Old Dec 7, 2007 | 04:14 PM
Sam Strano's Avatar
LS1TECH Sponsor
You can get away with most anything. But you shouldn't.. Getting rears first, if that's all you can swing is certainly better than none at all. However, the fronts weren't left at home when the car was driven and really aren't any less worn--though they aren't as terrible to start with as the rears are.
What tends to happen when you put good shocks on one end, and leave the other alone is you just see how bad the "stock" end really is. There are those that put on rears and not fronts and don't notice a difference, or much of one. That's generally because when you put cheap (either in cost or in refinement) shocks on, they often aren't really much better than the stock stuff that came off.
__________________
