Disadvantage to removing rear upper-spring insulators?
After the Moser 12-bolt install I notice my rear rides significantly higher than the front, this bothers me. I was hoping if I took out the rubber piece that sits on top of the spring in the rear it would help lower it. But, I wasn't sure if this would create a bad situation (creaking, spring eventually wearing through the sheet metal, etc). Anyone know?
Re: Disadvantage to removing rear upper-spring insulators?
Alot of guys pull of the spring isolater and replace it with 5/8" heater hose. It should give you about 3/4" of a drop, and the hose will prevent any squeeks or creeking.
Hmmm can you tell me how much I'll need, and where on the spring it should go? Wrap it on the first coil or maybe lay it across?
