centering the rear
Here is what I do (and there are many ways to skin this cat, so take this method with a grain of salt):
I put the car on ramps front and rear so the entire vehicle is off the ground, but all four tires are loaded. This just makes it easier to crawl under the car and adjust things for me, and it makes sure the suspension is seeing the same loads that it would if it were on the ground. Adjusting the panhard rod while the rear end is under full droop would be a fruitless effort...
I grab some 2" wide masking tape, two pieces of string, and 2 plumb bobs. All of these things are readily available at Sears if you don't have them...
The strings get taped to the fenders with the plumb bobs hanging from the ends, and so the bob is centered front to rear on the wheel/axle as well as somewhat centered on the axle up and down. I do my best to make sure they look the same on both sides.
I pop off my center caps on the rear wheels since they are easily removed, and I measure from the center of the axle on each side to the plumb bob with a tape measure. Just keep going back and forth and adjust until you get the rear centered. If you opted for the on-car adjustable piece, it'll be a snap...all you'll have to do is loosen two jam nuts and turn the adjuster whichever way you need to go. If you didn't get the on-car adjusable piece, you'll have to keep taking the rod end side of the panhard rod off to screw it in and out, and then put the bolt back through it and remeasure at the plumb bobs.
Once it is adjusted though, you should be good to go unless you change the rear ride height, at which point you'll be repeating this exercise.
If they say it can't be done they don't deserve to be a TECH!!!!!!!! I do these all the time at work.
Another thing we used to do when we would build a race car is get some masking tape and get some string with a weight at the end and hang it from the 1/4 panel and measure each side and try to even it up.
https://ls1tech.com/forums/new-products-showcase/825662-trz-3rd-4th-gen-chassis-style-arb.html
This thread shows it. Check it out, may be something you'd be interested in.
https://ls1tech.com/forums/showthread.php?t=825662
Great Info, and haha at "Skinning this cat"
