24 way QA1 settings?????????
I have a 2000 Z28 with mods below... I've seen plenty of threads about the 12 ways and where to start with them on the street and at the strip.... I just want to see where i should think about starting with the 24 ways on both the street and at the 1/4 mile.... I run 26'' et streets by the way...
Just like any adjustables you have to dial in from trial and error, every car is different. Try running softest setting and working around it after a couple of launches
On the street set it to the hardest settings and work your way down
As a conservative approach I would set:
Front: rebound around 5-8
compression around 14-18
Rear: around 8-10
Make sure you mount the ***** facing inboard and they will likely lower the car slightly too.
Thanks bro ur the first person that has givin me a start point with these things, everyone just says trial and error thats the only way... Well with 12 ways thats fine but when dealing with these 24 ways you have 570 plus settings that are possible, all i wanted was where i should kinda start with em, now trial and error is possible... and yes i have the ***** facing inboard... I really appreciate the help.
