Need part number for PHR support bracket
Old Jul 2, 2003 | 08:55 PM
Fulton 1's Avatar
Default Need part number for PHR support bracket
I'm trying to track down a part number for the panhard rod support bracket that mounts just above the pass side PHR attachment and bolts to the body on the driver's side. I think its probably the same part for all 4th gen's. Anybody happen to know the p/n?
Old Jul 2, 2003 | 11:22 PM
trackbird's Avatar
Default Re: Need part number for PHR support bracket
THat is the "upper panhard rod". I bent one on a 3rd gen once....but it is a rare case. Granitelli motorsports used to make an aftermarket one....but I don't think anyone ever bought them and it may be discontinued....scratch that....go here:
http://www.granatellimotorsports.com/gmpanhardrods.htm
There it is and it fits 82-02.
Good luck!
Old Jul 3, 2003 | 08:56 AM
Fulton 1's Avatar
trackbird, you Da Man! I wondered if anyone made an aftermarket version of it. Thanks!
Old Jul 6, 2003 | 12:33 AM
trackbird's Avatar
It is actually a boxed version of a stock upper PHB. YOu can source one from a junkyard, weld on some support pieces of steel and paint....cost: $190 less than the Granitelli part ($30 for the junkyard upper, $5 for steel and $5 for paint). But, I'm glad to help out....
Old Jul 16, 2003 | 08:56 PM
Fulton 1's Avatar
Just to follow up on this - GM references the part as "rear axle tie rod bracket brace" p/n 10019526. gmpartsdirect.com sells it for under $30. I could bend up a half dozen of those before the GMS unit would pay off
Old Jul 17, 2003 | 11:34 AM
trackbird's Avatar
Yea, I figured that "anybody was better than GMS" for price. That is why I mentioned that the say it is a reinforced stock part. Good luck!
