Prokit was to low for me what springs are just a little higher?
Old 01-14-2008 | 08:10 PM
Eatinstang4life's Avatar
Default Prokit was to low for me what springs are just a little higher?
Well I loved how the prokit looked it was just too low for my liking. What springs lower the car maybe 1/4" higher than prokit?
Old 01-14-2008 | 08:15 PM
Bow94z's Avatar
Strano rated @ 1.2inch drop
BMR, Hotchkis rated @ 1" drop
Old 01-14-2008 | 08:34 PM
mnypitZ's Avatar
I had the same problem. I had them on a week, and pulled them off and put on a set of Vogtlands. Inexpensive and far better and less drop.
Old 01-15-2008 | 08:21 PM
Sunset01SS's Avatar
10 Year Member20 Year Member
Hotchkis springs. That's what I'm gonna put on mine soon.
Old 01-15-2008 | 08:35 PM
The Guz's Avatar
Hotchkis springs settle a little more than 1". Mine settle a little more than that. Not to much. But the ride is great paired with koni's.
Old 01-15-2008 | 08:58 PM
letsrun97z's Avatar
do you wanna sell the kit you have
Old 01-16-2008 | 10:59 AM
Sam Strano's Avatar
LS1TECH Sponsor
I've had a few folks change from Hotchkis (which I also sell) to my springs and report the car rode better. Presumably because mine don't change rate as they compress and/or the spring does more work to slow the impact of the car on the bumpstops (and you do indeed touch the bumpstops with any spring). We know that the lightest rate isn't always the best because the LS1 Eibachs are pretty much the lightest, and tend to ride the worst.
There are lots of pics of cars with all kinds of springs, including Hotchkis and Strano. Use those to compare. In the end you can add what I said above to the fact mine also weight less too (15 pounds or so for the set) which is never a bad thing.
Shocks. Yes, I prefer to see a lowering springs used with a set of shocks that are appropriate, being that shocks are *spring dampers*. But mine don't work worse with stock shocks than other lowering springs do. In the end, both are a lower which leaves less travel for the shock to do it's damping in, and most all springs have more rate (normally at least 25% in front) than stock.
__________________
Old 01-18-2008 | 05:43 PM
fenix999's Avatar
What shocks do you recommend for HOtchkis springs b/c i have a feeling my stock shocks could use some replacing. I also have a feeling my car would ride MUCH better with new shocks. My car went through the torture of eibach sportlines and my front shocks are currently KYB adjustable crap shocks, and yes they ride like crap on ANY setting. Advice would be great, thanks
PS- and yea i would liek an option for shocks that doesnt run me big money, just a budget setup that works well-wanted to clarify that alittle b/c i dont feel like spending that much on just shocks
Old 01-18-2008 | 05:45 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
You could also go to AUTOZONE or similar and get a larger isolator[rubber puck] than you have now...
Old 01-19-2008 | 04:01 PM
EvilBLK02TA's Avatar
The first thing that popped into my head after reading your post- STRANO!!!
Old 01-19-2008 | 05:07 PM
JWS6's Avatar
How are those working for you? hows the handling?
Old 01-20-2008 | 08:30 PM
2000nbmZ's Avatar
eibach makes an slp spring that is 1in drop thats what i have on my car
Old 01-20-2008 | 08:31 PM
'02 WS6's Avatar
strano x2 thats what i have, will get put on when it warms up a little.
Old 01-21-2008 | 06:48 AM
Out1aw's Avatar
SLP Eibachs, BMR, or Hotchkis will all work well for you
Old 01-21-2008 | 07:59 AM
SOMbitch's Avatar
Strano x3!!!
Old 01-21-2008 | 10:32 AM
Dskeet6's Avatar
you could try using the hose mod as a means of raising the vehicle.... save you some time and money
Old 01-21-2008 | 10:36 AM
mnypitZ's Avatar
I like the stance, and they are far superior to the Eibachs. I have KYBs on there and I dont like they way they handle, so right now, springs YES, KYBS NO.
Old 01-24-2008 | 01:51 PM
Martin HD-28's Avatar
Hose mod?
Old 01-24-2008 | 01:55 PM
RooRnZ28's Avatar
i'm planning the switch in the next 3 weeks from the pro-kit to strano springs/koni's, i'll let you know whats up then! i am sick of these shitty springs with my stock shocks!!
Old 01-24-2008 | 05:25 PM
6SSPEED's Avatar
Not to jack the thread but if anybody wants to sell me their eibach pro-kit, please pm me.
