1973 camaro control arm removal?
Upper or lower? What's the problem?
Upper control arm:
Pop the upper balljoint
Remove the two bolts mounting it to the chassis
Lower control arm:
Remove the shock
Disconnect the swaybar
Pop the lower balljoint
Remove the spring (carefully)
Remove the two bolts on the lower
Upper control arm:
Lower control arm:
Remove the shock
