can it be dropped??
Old Jan 24, 2008 | 09:04 PM
wht98ls1's Avatar
Default can it be dropped??
i have a 98' z28 with 10.5 inch zo6 rims in the back and with 275-40-18 tires........i am wanting to lower the car....what do you guys recommend is a safe way to go?
Old Jan 24, 2008 | 09:08 PM
wg871's Avatar
Had a buddy running 315s on the back of his Z and it was low. I believe he had to roll the fender lips becuase it would cut the tires when it squats.
Old Jan 24, 2008 | 09:34 PM
Randy WS6's Avatar
mines lowered 1.75"with 315/35/17's and had to roll the finder lips ,You will need to buy you a adjustable pan hard rod if you lower, If you don't your rear will be offset to the passenger side, and will hat to remove the bump stop
