PHB adjusting question
Old Jul 9, 2003 | 03:28 PM
Z-Rated's Avatar
Default PHB adjusting question
I have a prokit and i am wondering how long the panhard should be. So if you have an adjustable panhard how long is it? so that way I can get a better idea of how it should fit and adjust the rear. Im asking this because my car was hit near the driver rear tire. So im afraid the fender might not be true, or other wise ill just plum-bob it.
Old Jul 9, 2003 | 04:21 PM
jpz28's Avatar
Default Re: PHB adjusting question
I want to know also!
Old Jul 10, 2003 | 06:51 PM
Z-Rated's Avatar
bump
Old Jul 12, 2003 | 09:35 AM
99 Black Bird T/A's Avatar
I didn't run my adjustable PHR all the way out to see that the max lenght possible was. I started with running the BMR out to stock lenght.
Depending on bad the car was hit, would it be worth taking it and getting it checked on a frame machine to make sure everything lines up like it should? Cost's about $50 or so
Old Jul 12, 2003 | 11:12 AM
DaddySS's Avatar
Take your measurements from the inner edge of the fender well from under the car. Lowerng with the prokit will push the axle to left about 1/4 to 1/2 inch so the PHB should be about 1/8 to 1/4 shorter.
