LCAs: What's better for Drag?
It depends what you want to do with the car. Since it is a drag car I assume you have or will change the rear end in the car? If so any time a after market rear end is placed in the vehicle we highly recommend adjustable components to help keep the rear end centered and to allow adjustments. Also if you plan on running a larger tire adjustable control arms and a panhard bar may be needed for the correct clearance. The control arms will allow you to move the rear end back or forward while the panhard bar allows it to moved side to side. This is very handy for those larger tires. Also items will solid bushings will perform better at the track.
Here is a few items I would recommend for a drag car, they are also very streetable.
Control Arms- www.umiperformance.com/2017
Control Arms with off-set Bushings- www.umiperformance.com/2017OF
Panhard Bar- www.umiperformance.com/2023
Control Arm/Panhard Bar Kit- www.umiperformance.com/201723
If you have any questions please ask and I will be glad to help. Thank you!
Ryan
Ryan
