front QA1 single install questions...
-- should i just buy the hardware from Thunder or get some grade 8 from the hardware store?
--it doesnt appear that the shocks have the thrust bearings, can the shocks still be adjusted for height on the car? will it be hard? I bought the spanner wrench also.
--I'm installing 275lb springs in the process so how will I need to set the shock to give it stock ride height? set the lower spring nut 1" higher?
this is what im getting
thanks for the help
No it isn't hard to adjust the springs if you have the spanner wrenches.
thanks for the help
just got the shocks today( the pic posted earlier above is all i got) and there's no hardware included. Does the Thunder racing hardware kit include all the hardware I need for the 2 front shocks? it's only $10 for the pair. The fronts dont have any rubber bushings, correct? any washers? just trying to figure theres out before i install them in the next few weeks. havent uninstalled my stockers yet
