Cutting Springs?
Personally i left mine in, but a lot of people use properly sized heater hose and wrap it around the first coil. You won't need an adj PHB for the majority of the cars out there, unless your car is right on the edge of factory tolerances.
is pretty much all stock except the hotchkis stb, so if i lower the back and raise the front it will even out the car... that's the look I want untill I can afford to spend the 8 to 900 on suspension parts that i want.
