700$ what the next ?
Old Feb 3, 2008 | 11:28 AM
camaro_best's Avatar
Thumbs up 700$ what the next ?
hi
time for some Suspension mod>>
for drag race .. my gols hit the 11s
what can i do with 700$ ... ???
My z now with 3500 2.5 str + 3.73 + M/t tires 275/60/15
Old Feb 3, 2008 | 11:47 AM
omcar's Avatar
get an adjustable torque arm, Qa1 adjustables on the rear and lower control arms.
Old Feb 3, 2008 | 12:39 PM
davered00ss's Avatar
Moderator
QA1 shocks will kill $300 of that budget.
Adjustable TQ arm will kill the other $400.
Old Feb 3, 2008 | 11:53 PM
HAL R Series Adjustable Front Shock $189.99 X2 and (what about the springs) ?
400$ for adjustable torque arm i ssw this at speedinc. it's only 230$
UMI2205 UMI F-Body Transmission Mounted Adjustable Torque Arm $299.99
btw. what do think about this
(Rear Control Arms + Relocation Brackets + Panhard Bars +Subframe Connectors )
or
(Qa1 R Series Front Shock W/ 275 speins +Competition Engineering Rear Shocks w/stock springs )
I have question about the TQ my plan in the future the TH400 + 12bolt rear bolt
what i should do now ?
buying the TQ or forget it now??
Old Feb 4, 2008 | 12:00 AM
Sunset'01Z's Avatar
how is your launch?
Old Feb 4, 2008 | 06:05 AM
Originally Posted by Sunset'01Z
how is your launch?
i don't try it ...
this my old # 2.028 60ft just lid - catback - lt's - BFG 255/50/16
Old Feb 4, 2008 | 09:15 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by camaro_best
hi
I would do lower control arms(TCA001) and relocation brackets(CAB002) to help make the most of the tires you have. If you have any questions regarding out product line please feel free to ask.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Feb 4, 2008 | 09:20 AM
transamws6_97's Avatar
lower control arms, lca relocation brackets, subframe connectors, and torque arm would be a great start. It's what I went with. If you are looking to drag and make this into the 11s I would definitely suggest a chassis mounted torque arm over the full length ones. That will set you back around 400. LCA and relocation brackets should set you back about 200 and sfc about 150.
Old Feb 4, 2008 | 09:37 AM
thanks all
I have question about the TQ my plan in the future TH400 + 12bolt rear bolt
buying the TQ now or forget it now??
Old Feb 4, 2008 | 12:13 PM
might as well get it now. if you get a chassis mounted torque arm it doesn't really matter what transmission you have in there. I highly suggest the chassis mounted torque arm as apposed to the full length.
Old Feb 4, 2008 | 12:48 PM
thanks
Old Feb 5, 2008 | 07:15 AM
ssvert99's Avatar
i have a package with a chromemoly adjustable torque arm, crossmember with adjustable height pivot link and driveshaft loop, chromemoly adjustable lca's with teflon lined heims, and lca relocators. the pivot link attaches to the crossmember with a energy suspension poly bushing to eliminate street noise. all parts powdercoated. 685.00 shipped.
Old Feb 5, 2008 | 10:18 AM
nice ..
But i'm in 'saudi arabia'
Old Feb 5, 2008 | 10:39 AM
robertbartsch's Avatar
TH400 trannies are bullet proof but VERY heavy, which is not good for a drag car.
Old Feb 5, 2008 | 04:17 PM
00 Trans Ram's Avatar
With $700? I'd lose weight out of the car. At 3500lbs, you've got a lot of stuff to get rid of, even on a daily driver.
Old Feb 6, 2008 | 09:50 AM
ssvert99's Avatar
nice ..
i can ship overseas...no problem. FedEx worldwide. actual shipping charges will be applied is all.
pm me with shipping info and i can give you a quote.
